Download
CSS SCI FI 2.1
Contains 12 custom maps with scripts, plus scripts for 15 of the original CS:S maps. Includes latest full version of SMOD and the SMOD configuration utility.
Contents
SMOD 39D2 (full)
SMOD Configuration Utility 2.1
Maps and scripts: CS_Beirut_HDR, CS_Harvest, CS_Xcom, DE_Atown_v1, DE_Battleship_HDR, DE_Biolabo_v1_2, DE_Bluecorridor, DE_Monach1, DE_Lochs2, DE_Nightfever, DE_Toxin_50, DE_Venice
Scripts only: CS_Assault, CS_Militia, CS_Office, DE_Aztec, DE_Cbble, DE_Chateau, DE_Dust, DE_Dust2, DE_Inferno, DE_Nuke, DE_Piranesi, DE_Port, DE_Prodigy, DE_Tides, DE_Train
Size
190.51 mb
Download mirrors
Computer Games
Fangaming
Filefront
Fileplanet
Fileshack
Gamershell *
Gamespot
Half-Life 2 Files
Internode Games Network
Moddb
PlanetPhillip
Strategy Informer *
Vossey.com
Torrent file:
Gameupdates *
*fast server
CSS SCI FI 2.0 to 2.1 patch
Patches previous CSS SCI FI version 2.0 to 2.1. All players using the 2.0 version should download and install this patch. Players new to the game should use the CSS SCI FI 2.1 full installer above.
Size
6.17 mb
Download mirrors
Filefront
Fileplanet
Gamespot
Half-Life 2 Files
Moddb
Strategy Informer *
Requirements
Half-Life 2
Counter-Strike: Source
Installation
CSS SCI FI is packaged as a fully functioning installer. To install the game, ensure you have a full version of Half-Life 2 and Counter-Strike: Source installed, then run the installation program.
During installation, SMOD 39D2 will be installed to your SourceMods directory, and CSS SCI FI will be installed within the smod folder. All custom Counter-Strike: Source maps and nav files will be installed to your cstrike\maps directory as normal.
During installation you will be asked to choose a number of configuration options. All options can be adjusted at any time by using the SMOD Configuration Utility. For more about this feature, please see the configuration page.
Running the game
CSS SCI FI has been fully integrated into the main SMOD chapter menu. To play the maps as a single player campaign, ensure "Campaign Mode" is enabled in the SMOD Configuration Utility, then run SMOD. The first two chapters in the New Game menu show the start of each campaign. Campaign 1 features 12 custom maps, while Campaign 2 features 15 retail maps.
You can also play each map one at a time. If you wish the map to reload when the objectives are complete, select "Round Mode" in the SMOD Configuration Utility. To play a map, start SMOD and then select "New Game". You will find all 27 CSS SCI FI maps, followed by Lost Coast and the Half Life 2 single player campaign.
Because the chapter menu is limited to 32 chapters, not all of the HL2 single player chapters can be displayed. If you wish to play a Half-Life 2 single player campaign chapter which starts at a different point in the story, please run the SMOD Configuration Utility and choose the option to install the original HL2 chapter menu. Using this feature you can switch between the CSS SCI FI menu and the HL2 chapter menu at any time.
Like many HL2 mods, please note that loading times are very long initially, but improve once the game is running. Please be patient.
What to do when SMOD is patched
SMOD is patched and upgraded frequently. All new releases can be found at the SMOD forum or at the official download mirror. For each numbered version, such as 39, there will be a cumulative lettered patch, for example smod39e.zip. To install, unzip the patch to your SourceMods directory, being sure to overwrite all files. To install an updated numbered version of SMOD, follow the same procedure. It is not necessary to delete your SMOD installation prior to upgrading or patching.
After patching or upgrading, you must run the SMOD Configuration Utility and choose the option at the end to "restore core files". This will ensure that you have both the latest version of SMOD as well as a fully functioning installation of CSS SCI FI. If there are any incompatibilities between a new SMOD patch or version and CSS SCI FI, a CSS SCI FI patch will be released via this website and the CSS SCI FI Moddb profile.
Compatibility
CSS SCI FI has been designed for SMOD only and should not be used in conjunction with other SMOD mods. CSS SCI FI is not compatible with "SMOD Tactical" or the "SMOD mapadd generator".
Uninstallation
To uninstall CSS SCI FI, exit Steam and delete your SourceMods\smod directory. This will remove CSS SCI FI and SMOD.
Changelog
Click here for a full changelog.
css sci fi amphibian mods moddb Valve SMOD This work is licensed under the Creative Commons.
